It's also likely the screwdriver/stripper blade isn't hardened to the same level as the main (spear) blade. It could be 'sharpened', but likely wouldn't hold a fine cutting edge very well at the geometry used on a true cutting edge. The driver/stripper tool is made for twisting, prying, wire-stripping & driving screws, so the emphasis is on greater toughness (usually means 'not as hard', in real terms), instead of fine edge-holding. Not to mention, a hardened & sharpened cutting edge on a wire stripper is more likely to damage the copper/aluminum conductor itself.
I have three such knives from Case, two of them are the standard 12031L pattern (1 blade, and the driver/stripper tool) and the other is the 13031L with the additional hawkbill blade. They're nice knives. One of the 12031Ls is a well-used 1974-vintage knife that's missing the bail and the walnut is somewhat chipped as well, and I've been pocketing & using that one lately. It's still a good workhorse and I'm not worried about blemishing that one. The other two are more or less in pristine condition, still 'shiny' with their original mirror-polished blades.
