Case's CV is at it's very, very best when ground THIN to a razor's edge. I've favored anything around 25-30° inclusive for it; I have a 1990s-era CV trapper with (likely) a sub-25° inclusive edge on the clip blade, and it's a wicked slicer for appropriately-selected tasks. The steel isn't really hard enough to avoid some deformation or rolling in things like zip-tie cutting, though a 25-30° inclusive edge can still be restored very quickly. I've decided it's better to sharpen for the better slicing at sub-30° angles and touch it up a little more often, instead of maintaining a thicker edge that never really cuts all that well in the first place. Even at 40° inclusive, the steel will still dent/deform somewhat in cutting harder materials, like zip-ties. Only difference is, a thinner geometry can still cut reasonably well, even if the apex has dulled a bit; a thicker geometry will become instantly blunt and essentially useless when the apex isn't crisp anymore.
For most any knife, I'd still favor 30° inclusive or lower; most any decent steel should hold up reasonably well at 30°. For the other knife you mentioned (the bush crafter), I'd start there. If it turns out to be a little fragile in use, just add a slightly wider microbevel (35-40°) to the edge. I'd never go any wider than 40° on any knife edge; cutting performance really degrades above that, even when the edge is new and crisp.
David
