- Jul 30, 2006
So there was this thread in Traditional about CV steel.
http://www.bladeforums.com/forums/showthread.php?t=592586
Then Tru-Sharp got mentioned.
Then the question of which was really better.
Then the question of how hard were they.
Inquiring minds wanted to know.
oh, oh.
I bought a Case Mini-trapper in Tru-Sharp and a Case Sodbuster in CV. Both had the yellow synthetic handles.
The Sodbuster felt rather gritty as I moved the blade. Added some triflow (oil with Teflon particles) to smooth it out. It was still a bit stiff, but got rid of the gritty feel.
The mini-trapper was smooth and solid from the get-go. Nicely built. Very solid with good fit and finish.
OOB sharpness. Both very sharp. The CV would push-cut newspaper at the place where I held it. The mini-trapper would not, but was still very acceptable for sharpness.
I slipped by the metallurgical lab at work and borrowed use of the Rockwell tester. It is a nice machine with digital readout. It is recalibrated every 6 months to a standard traceable to the National Standard.
CV was 54HRC
Tru-Sharp was 55 HRC.
Reality check.
I note that the AG Russel web site says that the hardness of Tru-sharp blades runs 54-57 HRC, so my results sound normal.
So, that being said, how do they compare to one another in edge retention?
In making cutting comparisons between alloys, I prefer manila rope to cutting cardboard. I sharpen to a set angle, cut a set number of cuts using a set length of the blade, then examine the edge with a hand lens looking for damage. Normally I use 3/8" diameter because that is what the local HD carries. The advantage to rope is that it eliminates the effect of blade shape. As the rope fibers are cut, they pull away from the blade, so the only variables are the steel, the edge angle, and the sharpness.
I use a Sharpmaker to set a uniform 15° on the blades I am testing. I sharpen on the coarse until I can see no edge under a 3X lens, then move on to the fine.
I have a simple test fixture that consists of two boards side by side with a small gap between them. I cut the rope over the gap. That way the rope is supported, but I do not dull the knives on anything but the rope.
For this comparison, I made 10 slicing cuts, using a 1½" section of each blade to slice through the rope. Then I looked at each edge under a 3X lens using a high intensity halogen light to look for damage.
I repeated the process 3 times. The CV showed less damage in each case. The CV stayed sharper.
I might add that while both were REALLY easy to sharpen and both took a really great edge, the CV was easier to sharpen.
oh, oh.
CV was 54HRC
Reality check.
