Been wanting to do a sharpness test between Case and Rough rider for a while. I didn't have matching knives but all were unused knives and I tried to match the blade size and shape as well as I could. The handles were somewhat different which could make a minor difference. I am a sheath maker and leather smith so I used strips of 10 oz veggitan for cutting as I am very familiar with the feel, the strips were 1/2 inch wide. I used a crunch and pull for each cut in the first inch of all blades. Here are the knives. and the results.
[/url][/IMG]
Case mini copperhead pen vs RR peanut pen. This was the only blade that Case won. Both blades needed more pressure than the bigger blades. The case blade was slightly sharper.
Case Mini copperhead Clip vs RR clips on both the peanut and small single blade Barlow. No contest between the copperhead and the RR peanut the RR sliced like butter while the Case clip dragged and the Barlow was sharper than both.
[/url][/IMG]
I used the Case medium stock vs and what RR calls their 3 blade Barlow "sabre blades" for cutting. This one really surprised me, the RR cut 40 cuts like butter and then 40 more, the case dragged through 10 cuts using a great deal more pressure.
The RR sabre blade and RR clip on the small barlow were BY FAR the sharpest blades. So much for the much maligned 440a .
Best regards
Robin
Best regards
Robin
