I recently got a case large stockman 6.5375 "Bone stag" that should be stainless steel (SS marked on the blade tang).
However, I noticed recently that rust spots are appearing at the basis of the blade. I will post pictures later but basically, when you hold the knife closed looking at the blades, the part that hold the spring when the blade is opened seems to miss the shiny "coating" that the rest of the blade has. Right there I observed spots of red rust that keep reappearing even after I brush it out. The mains body of the blade however, is definitely stainless.
So is the "SS" version of case knifes are really stainless steel or is it just a protective coating?
The red rust also seems to accumulate on the inside part of the backsprings but not on the outside part of it so I feel lost about the steel used.
Can a stainless steel be only partially stainless? For example, my victorinox or opinels (stainless) never had a spot of rust and are super easy to sharpen. I have an Higo knife (carbon) that I can put screaming sharp but that take rust when used on food but the rust is all over the blade. On my case 6.5375 it is much more difficult to obtain a good edge (I am a beginner) so I guess the steel is harder. Does this correlates somehow with the rust issue?
Thanks for your feedback!
