Case TruSharp Vs. CV, Vs. Boker C75 Vs. Buck 420HC Vs. Victorinox, my observations...
Over the past month or so, I've been putting my new slippies through their paces, seeing how they compare to my more familiar steels, these are just some off-the-cuff, completely unscientific observations....
My two baseline steels are Buck's 420HC AND Victorinox's "Mystery Steel"
Buck 420HC; Great stuff, gets Scary-sharp, dead easy to resharpen, holds an edge for an acceptable amount of time, and has exceptional corrosion resistance, almost up there with Spyderco's H-1 this is probably the gold standard for traditional pocketknife stainless steel, the ultimate "working man's" steel, ignorable, doesn't need babying, and very easy to bring back to a Scary edge, it may not have the mystique, aura, or "personality" of a good Carbon steel, but it's a darn good cutlery steel
Victorinox "Mystery Steel"; I don't know what kind of steel Vic uses in their pocketknives, but it's good stuff as well, even easier to sharpen than Buck 420HC, responds exceptionally well to stropping, handles abuse with aplomb (tends to roll rather than chip) and has almost H-1 rust resistance, the only downside of Vic steel is it loses that Scary edge faster than Buck 420HC, but it's even easier than Buck to bring it back to Scary, resharpening is trivially easy
Case TruSharp; I'd put it somewhere in between Vic and Buck 420HC, it gets a hair sharper than the Vic steel, gets truly Scary, but it also tends to raise a burr/wire edge a tad easier and edge rolling is a little more prevalent on this steel, it seems to be roughly equal with Vic steel for edge retention and durability, it seems to respond marginally less well to stropping though, a good, basic steel, but nothing really special or endearing, it's just sort of "there"
Case Chrome Vanadium (CV); Now we're talking, this stuff gets brutally, scary sharp, holds that edge for a decent amount of time, seems to be rather resistant to wear (better than TruSharp and Vic Stainless, pretty much tied with Buck 420HC), plus it takes on that wonderful multitone patina with use, under the correct lighting, the CV blades on my yeller Trapper show off iridescent tones of blues, purples, magentas and oranges, and the patina is a transient thing too, every time the knife is used, the patina changes, sometimes in color, sometimes in pattern, oftentimes both, it almost makes the knife seem to be a "living" thing the way that the patina is in a constant state of flux, I've found that having a well patinaed blade actually makes me *want* to use the knife more, to cut more different things, to see how the patina moves, and changes and adapts to it's surroundings....
It does require more conscious care, just like any other "living" thing (for lack of a better analogy), it needs a thin, protective film of oil to truly fend off corrosion (the patina definitely helps), it's not as "ignorable" as a good stainless knife, but it's also got more "personality" and presence than the basic stainless knife
Boker C75; very similar, almost identical to Case's CV, but it seems to be a bit harder, edges seem more durable and wear resistant, the Boker Whittler I picked up seems to have been ground with a rather obtuse grind angle and it's not Scary Sharp *yet*, it's taking time to get it where I want it, but I figure once I have it sharpened up to my preferred sharpness (30 degrees inclusive on the Sharpmaker, then stropped and polished on 1000 grit sandpaper), what I like to describe as "Monomolecular" sharp, it should hold that "Monowire-level" edge for a good deal longer than the Case CV, or even the Buck 420 HC
In terms of overall pleasure of use and performance, best to "worst", I'd rank my collection thusly;
Case Yeller CV Trapper and Boker Whittler; tied for first, closely followed by my redbone SS Peanut
Buck 110 (and soon to be joined by a 301 Stockman)
Victorinox SAKs (various)
Case TruSharp Stockman
Good review thank you.
I've had experience with all of theses teels and none are in any way poor:thumbup:
When I ran side by side manila rope cutting comparisons with Buck 420HC, Case CV, and Case Tru-Sharp, I found that the Buck held an edge best. The CV was a definite notch below it. The Tru-Sharp was half a notch below the CV. My test method is qualitative, so that is as much as I can say. I find the differences noticeable in daily use.
I found all of them easy to sharpen. I think the CV was easiest, followed by Tru-Sharp, then the Buck.
I said all that to say, "My results were about the same as yours."
Hi,
I've not had a lot of experience with Boker C75, but I thought it was just a bit softer than Case CV. I had a Boker Copperhead briefly, and I thought my Case Canoe in CV held it's edge better. I gifted the Copperhead to my Father-in-Law, he loves the thing. He really uses it hard, almost abusing it. And it has held up very well for him.
I don't mind Case Tru-Sharp at all. It works well for what I think smaller slippies should be used for. I really need to get a USA Buck. I've only got two China made ones in 420HC, to see if there is a difference.
dalee
Good review. Enjoy other peoples opinion on knife steel and edge holding. Knarfeng, I tried cutting Manila/Hemp( not sure is is is Hemp or Manila or Manila Hemp) rope for edge holding after reading articles by Steve Dick and Wayne Goddard in Blade and Tactical Knives. I was amazed at what I thought were sharp knives just slide over the rope. And how quick knives dulled. I agree pretty much on your review. I do like Vic. SAKs and how sharp you can get them quickly and how smoothly they cut. Another medium I use is Basswood and you would be suprised how some knives will just gouge or slip over the wood without cutting. If a knife cuts well on rope and wood it will work on day to day cutting chores. Makes you think twice about the Tactical knives which most are to thick to be good cutters not all but most are.
RKH
