Case's site (link below) lists the handle/pattern codes for several types of handle materials, like '6' for jigged bone (usually; sometimes jigged synthetic or wood laminate), '5' for stag, etc. One of the codes listed is the uppercase letter 'I' for (both) ivory and for imitation ivory. Their description mentions that the imitation ivory is a 'composite' material. Maybe some of the old 'white composition' knives might be actually be classified/named as 'imitation ivory' instead, and perhaps the pattern numbers might include the 'I'.
http://www.wrcase.com/case_college/handles/handlematerials.php
"I - Imitation Ivory
Not currently used at Case, Imitation Ivory is a composite material that looks like natural ivory. "
The mention that it's not currently used might(?) imply that it was found on some of the older knives.
Same page also lists the code '4' for 'smooth synthetic':
"4 - Smooth Synthetic
Poured plastic or Delrin® molded handles made in most any color except black and yellow. "
This '4' code might be more likely for the white comp handles. I'm seeing a 5-1/2" Melon Tester pattern listed in my guide(
*) with 'White Composition' handles, and listed under the pattern# 4200 SS (2 blades). Also seeing a 4100 and 4100 SS Melon Testers. Vintages of the Melon Testers run from 1960 through 1974. And a 3-1/4" Budding Knife in white composition, pattern 4103B&G, from the 'Tested' era (pre-1940).
One thing for sure. If the pattern number for a particular knife begins with a '3', then it's definitely 'yellow' composite/synthetic. I do know Case started using the yellow comp a very long time ago (pre-1940, I think). My guide mentions a 'white liner' version of 'yellow', which existed on pre-XX era knives (pre-1940) and is described as having a 'deep glossy yellow color handle with a white line around it's outer edge.' Interesting...
* The guide I'm referring to = The '
Official Price Guide to Collector Knives', Fourteenth Edition, by C. Houston Price; 2004)
David
