- Jun 11, 2006
I am considering trying to cast a few knife bits from bronze as I think it would be fun as well as an efficient way to conserve material. But I have a few questions as to what can be done. In the past I have used wooden molds to case lead based aloys and it works good. The wood chars but holds togather. But on bronze the temp is double and don't know if the wood would hold togather long enough for the bronze to cool. I know green sand and wax plaster cast is the most common way to do it but was wondering if wood could work to get a rough shape. Now the sand brings me onto my next thought. Can guards be cast around tangs. I'm working on a few seax blades and with the full flat grind all the way out and off the tang. This means the tang is triangle shape and that got me thinking about just casting a guard around it. My thought was burry blade in (green)sand with the tang and recosio exposed. Then shape the sand to your guard shape and cast. Guard would then be pressed off and cleaned up. I'm not expecting a super tight fit to the tang in the as cast state but that can be fixed with pressing.
Thanks guys for any tips you can provide
