Strider
Yes, but you are lucky to have access to all types of other stuff I can only dream about!
TShloser, whoever you get to make your knife must cut of two or three pieces, about one sq. inch in area. He must then immerse it in oil. Not mineral oil. Use linseed, sunflower or other types of vegetable oils. The ideal is to have a thermometer in the pan. Bring slowly up to heat. Check when then little bubbles start to rise and make a note of the temperature. Let the temperature slowly increase and check every 10 degrees. Note where the edges start to crisp like pork crackling. Note the temp. The second temperature is too high, the first is about right. Cook the other piece of horn for ten minutes at a temp that is between the two.
Take it out after about five minutes, check that it is relatively soft and pliable. If it is, put it back for another two minutes, take it out - QUICKLY! and clamp on a flat surface, I use a piece of 1/2 inch steel plate, with a piece of soft wood on top. For the test piece one G clamp is enough. When the piece has cooled, about ten minutes, take it out, check for flatness,( if it doesn't stay flat, your temp is too low or you have been to slow in the clamping) that there hasn't been a colour change (wipe of the oil with a spirit rag and polish)or crisping of the edges (too hot).
With thin horns like impala and eland I make use of fibre liners to thicken the slabs slightly. For instance, on a impala horn, which is black, I may use a white liner against the horn and a black liner between the white liner and the tang. With a steer horn which might be sligtly translucent, one may use any colour you fancy and it will show through the horn as a tint. example: Red liner will give the translucent horn a pinkish tint. The best is to stick a few types of liner on piece of horn and see which ones you like best. If you do not want the edge of the coloured liner to show, use candy wrapping foil.
Tiaan Burger
http://www.limpopo.co.za/burgerknives.htm
First rule of martial arts: Nobody moves faster than a bullet!
[This message has been edited by Tiaan (edited 04 February 1999).]
