Thank you so much for your response. I have heard a lot about CBN stones lately and so was wondering how well it worked on high carbide high vanadium steels. Thank you for clearing that upFor the steels you mentioned, elbors will work fine.
In my experience, elbor and diamond work pretty much the same. Although there is a popular opinion that elbors supposedly work softer than diamonds due to the shape of the crystals, diamond has fewer faces, so it works more aggressively. But in the technical literature, I found only that elbors are used in the case when high temperatures occur during processing.
There is a nuance when working with diamonds or elbors: if rough stones are used to form the edge, they will form deep furrows that will be very difficult to destroy with subsequent stones. Therefore, it is better to form the edge with medium stones, then the lines will not be so deep and it will be easier to remove them.
Would diamond work better tha cbn though?For steels with a lot of vanadium, such as c90v, c110v, c125v, rex121, v10, v15 and others, from my experience, ONLY diamonds or elbors can be used to form an edge. Then you can work with silicon carbide, aluminum oxide does not work, or to be more precise, it works very, very slowly
Thank you very much for your replies. I appreciate it a lot. Do you have any experience with electro corundum by any chance?My experience says no, it won't work any better. But it will not work worse
Yes, I used it. I use it from time to time on "simple" steels, where the price of the stone corresponds to the price of the knivesDo you have any experience with electro corundum by any chance?
Thank you for all this info! Your input helped me a lot. Much appreciated.If you want to take a full set of diamonds or elbors, then at the initial stages you should take a copper-tin bond, and then a resin bond, for example: 200/160, 100/80, 50/40 - copper-tin, 20/14, 10/7, 5/3, 3/2 - resin bond
Thank you C chalby .CBN and diamond at a practical level should be considered more or less the same. As the previous poster said, resin bonded diamond/CBN will generally be better for refinement at the expense of some speed. Metallic bonded diamond/CBN is the opposite. I don't know much about hybrid bonds.
Pardon, what are elbors?For the steels you mentioned, elbors will work fine.
It is CBNPardon, what are elbors?
Sorry about the late reply. I only have service at home, via satellite. Thank you for the response. Sounds like I would be well served with CBN.Vanadium carbide ~2800Hv
cBN ~5000Hv
