- Mar 18, 1999
I am sure that most if not all of you have done this in the past but just in case.....
Instead of using a scribe to scribe the centerline on your blade before you grind you can lay your blank on a flat work surface and using a drill bit of approximately the same size, scribe the center line with the drill bit laid down on the surface as well. I have used a drill bit just a little smaller or larger and turn the blade over and do the other side. This will give you two "center lines" or "grind lines" to grind to.
C Wilkins
C Wilkins
