Centering Para 2 Blade
I have tried several times and it just won't center up. How do you guys center your blades?
it's very easy on the para 2... there's two pivot screws so if you tighten one and slightly loosen the other, the blade moves. just mess around with that and you'll get it. if one side doesn't work then try the same thing on the opposite side.
Thanks! It seems I have bigger problems now though. When I went to the other side the pivot screw didn't have as sharp
of teeth and now the tool I was using is not getting enough grip to unscrew it.... Are there any ideas on how to get it out?
what tool are you using? i've never experienced that problem on my para 2's but perhaps you need a new tool?
Its a T-tool from Kershaw.... Did the same thing to my 0350 but I thought that was my fault but it seems it may have been the tool then and now....
Thanks for the help four_shore! I went to my local Lowes and picked up a torx bit set and it worked perfect! I got my blade nice and centered! Thanks again!!!
