Man, CRK flat grinds their scales to be perfectly parallel. So if there is no blade play when open, all you can try is to loosen the scale screws and pivot, open the blade, tighten the pivot just until there is no play, then then tighten the scale screws and close the blade to see where it's at.
If it is still off center, you can try loosening all the screws, wedge the blade toward the side you wish it favored more, tighten up the scale screws and pivot, then see where you're at.
It has taken me an hour to get mine perfectly centered before, so try combinations of the above.
If it doesn't work, send it in to CRK. Solice yourself in the fact that when it returns it will be just like you got a brand-new knife.
The wait will be worth it! And your dilemma will be over.
