Odin's Son
Banned
- Aug 29, 2013
What do the pros think about Ceramic or Diamond Pull-Through Sharpeners? Are they better than carbide tungsten pull-throughs?
I'm not a pro, but there's no such thing as a "one size fits all" bevel angle. Maybe ceramic or diamond would make a less "butchered edge" but pull throughs in general are nasty.
I have made my own Ceramic knife sharpener and that is all that I have used. I use it on my Kershaw leeks, case and even the cheap china crap knifes. I don't see what the big problem is with them. here is a picture of what it looks like.
Hi, thank you for your answers David, very knowledgeable. And I can really see you're obsessed with edges.![]()
No problem at all, with that type, when used like most 'V-crock' sharpeners (Sharpmaker, Lansky Turnbox, etc.), by sliding a blade edge down the rod, toward the bottom of the crossed 'V', one side of the bevel at a time. Configured like yours, it's not actually a 'pull-through' sharpener, as they're normally used.
But that's not what the OP was referring to (assuming, anyway), in which the very, very short inserts necessitate placing the blade edge directly at the bottom of the 'V', and then dragging (pulling) the blade through it. Here's an example pic of this type, seen with both the ceramic (top) and carbide (bottom) inserts:
David
Cuz this is what they do![]()
Here's where I call BS. This is useful as ad copy, so it's wise to break out the skept-o-meter when evaluating.
We're presented with three micrographs of edges to compare the virtues of the Wicked Edge to pull through and electric sharpeners. While it claims they're at 230x magnification, it looks to me that the pull through and electric pix are under a higher magnification than the Wicked Edge. One could easily use the same trick to "prove" the Wicked Edge is inferior, since all it will take to show a jagged edge is enough magnification. Strike one.
The only virtue one can truly glean from the ad is that the Wicked Edge produces an edge bevel that looks more uniform. It shows nothing about sharpness. Strike two.
It's not clear the advantages amount to much for most folks. Most people don't evaluate their knives by how they look under a microscope. Instead they go by how sharp they are in actual use. This is why pull through sharpeners are successful devices. Take a dull knife, pull it through a few times, and it's sharper than it was before, very little skill or time needed.
Wicked Edge is a fine product. My only criticism is that, like most sharpening systems, it teaches you a recipe. One that's linked to a gadget, in this case. Which is fine, but as a skill, that's no better than using a pull through. Ultimately, when one learns why the recipe works, your skill makes you independent of gadgets, to the point where you can be successful using any gadget or method. Including the lowly pull through.
In what context? I would argue that the reason why pull through sharpeners are "successful" devices is because most people don't know how to sharpen a knife. That and because most knives from grocery stores, Walmart, and Costco are so soft that you could sharpen it on the sidewalk with no problem:thumbup:. Otherwise the fine grit abrasives in the ceramic pull throughs would never make a dent in say, S30V.It's not clear the advantages amount to much for most folks. Most people don't evaluate their knives by how they look under a microscope. Instead they go by how sharp they are in actual use. This is why pull through sharpeners are successful devices. Take a dull knife, pull it through a few times, and it's sharper than it was before, very little skill or time needed.
