You can use a little water if what you are tumbling is stainless, or else use water w/ baking soda if you want to prevent rust on carbon steel. You will need something to lubricate though... some have used oil too.
I started with a polished SS E4 clip. This clip was ran 4 hours in a vibratory tumbler with 5/8" triangular ceramic media with a small amount of water. The result is a soft satin finish, almost like bead blasting. I believe a rotary drum tumbler would produce the best effect with less run time. Thanks for looking.
