Ceya's TRIDENT WARRIOR FB..."live test!"
Aloha all!
Permission granted from Ceya to live test his TRIDENT WARRIOR! Yeeeeeeeaaaaaahhhhhh, as this FB absolutely "cries out for use!"
Stuffed some old rolled up carpet in a pair of old denim jeans. Placed it on my "practice pole" free hanging by the belt loops w/ parachord. The TRIDENT cut rather deeply during slashes, and to me, any knife that can cut material of this density "free hanging" is a good one! Of course it cut through the jeans, but it also went through a FEW layers of the carpet. Damn! Following up some slashes w/ backcuts were quick, and left some nice "wounds". "Speed thrusts" left holes in the jeans, but didn't penetrate the carpet. I believe however, had the target been stabilized, the TRIDENT would've went in deep!
I then went into my forest and selected a piece of seasoned guava branch...about 3/4 in diameter. This wood is VERy pliable, yet HARD! I stuck it in the ground and delivered an upward angled slash from my right hip to left shoulder contacting the stick on the way up, then I quickly reversed the motion, contacting the stick on the way down. I was VERY surprised when the stick "fell in half" as my second cut met the first, thus splitting the branch!!! I tell ya, this was right out of a Samurai movie! LOL! Most times, the stick will go flying or I don't meet the first cut EXACTLY, PLUS it has been rainy as of late so the ground was soggy, making a less stable base for the branch. Cool!
I then wrapped a piece of plywood with the carpet. Did a few thrusts, the first being about 40%, then gradually i went full on. The carpet was about 3inches thick and although the initial thrust didn't go all the way to the wood, the others made a loud "thunk" sound. The handle started to get a bit slippery, so I stopped the thrust test as I do want to keep my fingers! Remember, the TRIDENT has a sharpened "false edge" at the tip, so I was somewhat hesitant to look at it in fear that it would be damaged. Tip damage? Zero. Plywood? LOTS! I then unwrapped the carpet a bit and slashed a corner off with relative ease. the cut wasn't perfectly straight as the carpet "gave" a bit when struck, so the cut was sorta curved. It did fall to the ground though! Taking the carpet off completely, I then did a few hammer strikes and backfists with the pointy pommel. I went HARD on these, and managed to sink the pommel alomost to the location of the lanyard hole. Slashes, thrusts, pommel strikes...all very comfortable w/ Ceya's TRIDENT!
Now for "utility use". I whittled on a 2 inch diameter Guava stick. Ho hum...The TRIDENT did this with EASE and would make an excellent skinning knife. Taking that same stick, i stuck it in the ground. Placing the TRIDENT's edge on top of the stick, I used another Guava stick to pound that massive "ramp" on the spine of the blade and proceeded to split the stick in half. I then cut carpet again, but in a "normal fashion", cardboards of various density, poly rope...this part was boring as the TRIDENT went right through them all. I was eyeing out that plywood...wanted to throw the TRIDENT but this knife was sent to me for evaluation, not abuse. (Although the TRIDENT is a beefy, thick blade and could've handled it!)
Completion of the live test revealed 0 scratches, 0 tip damage, 0 pommel damage...and the knife was still sharp!? AGAIN, props to DMKnives!
CArry modes were SOB and neck. SOB was VERRRRY comfortable and almost felt pretty good as the width of the sheath supported the small of my back somewhat. Drawing was quick, replacing slow. (Didn't wanna stab myself here, so i wasn't in any hurry to put her back into the sheath!) Standing, running, sitting, driving...SOB was fine.
Necker mode...I thought this wasn't gonna work out, as the blade is pretty hefty. Thought wrong as I wore it under my Class B uniform for about 6 hours tonight! It left no print, and leaning forward, the TRIDENT didn't reveal itself...something I thought it would do. Jumping up and down, off the bench outside the facility, the TRIDENT stayed put. Draw was pretty hard on the ball chain, as it felt like it was gonna bust. Think the hollowed out para would work well here.
ANYWAYZ...again Ceya, I was very HONORED to evaluate this fine TRIDENT WARRIOR of yours! A big mahalo for allowing me to test it live! This part of the eval has TRULY made me a believer in your design. I wa very impressed. Again, from a MBC standpoint, the handle is and worked fine, but to fully appreciate the utility use...a wee bit more handle belly please! No matter which company mass produces the TRIDENT, I am buying one! In fact...I am kinda attached to this proto! LOL! e me please if this is possible!
Aloha all!
