- Jan 5, 2007
Hi guys...
again, due to lots of mods here and there, and the fact that Tyrkon Lawson started a lovely looking project on his favorite NO-E :thumbup:, I decided to give it a shot with my CG FBM...
I litterally drove down the local DIY Depot immediately in order to get some paint stripper...
Here we go:
This first pic shows what I'm using... new box of sandpaper (can only buy up to 600 grit anywhere I've been!) which
has 240, 400 and 600 grit papers... the paper is wet or dry, and using it wet apparently makes a smoother finish, so I guess that'll be the last coat I'll use after the 600... some soaking wet 600. This paint stripper is a gel... its the only one I could find, and thought it was the bomb, until I saw Tyrkons update stating that he covered his for only 15 minutes... I had to wait 2hrs, and did that TWICE!!!! A cork thingy, my FBM and my handy D'Allara drop point sypdie... (intended for just cutting masking paper etc but never actually got used)
The coating was a mare to get off, so respect to Jerry and co. for really sticking this stuff on well
I then used a chisel and small flat headed screwdriver to strip the coating off, which took about 20 minutes in all, plus a bit of wire wool to get the harder stuck on stuff... there were a few patches of this.
Next up is the blade after the coating was removed... the metal is a 'gun coat' type colour.. quite dark, which actually looks really cool... but it was coming off
I then washed the blade off - BTW, the paint stripper did NOTHING to the micarta.. its some really tough stuff.
This is a shot of the blade after a good buffing with 240 grit sand paper... took about 20 - 30 minutes to get a fairly even spread with the cord thingy wrapped in sandpaper...
Here is a pic of the micarta handle slabs against the steel... although it was the standard 'black' micarta handles, they look kinda green to me, and I really REALLY like the look of them against the bare steel
And here is one more of the blade, with some natural light dashing off of it...
You can see that the corragated lines still have some 'gun coat' darker bits left... this is fiddly to fix, and requires a lot of horizontal sanding with the tips of your fingers nestling in the crevesis and then rigourously and rather frantically sand like a madman... but its worth it! (and for the record.... it works)
There is still a lot that needs doing to this... I've got to figure out a way of getting the harder to sand parts (like around the pomel and talon holes) up to the same end result, without taking off the micarta slabs, as I don't know how to or how to put them back on without breaking it
May break out the Dremmel multi drill
I will be slowly rubbing the blade up to 600 grit paper, with a final wet sanding after that... getting too much higher will start to put a shinyer 'mirror effect', which I'm NOT after... Satin FTW
Thanks for the previous threads to look at similar mods, and also thanks to TK.. his post just made me 'get up and go', as it were - cheers bud...
After all this, I will take the convexed edge down even further.... it bites really well as is, and shaves hair, but can be that little bit more 'scary' - You can see the dodgy uneven convex sand marks in the first pic.. they didn't look nice, but the Mistress was super sharp... looks aren't that important in the user, although I think that'll be a different story when I'm done here...
I'll keep you posted
Thanks for reading....
Alex
Here we go:
Alex
