- Aug 12, 2002
OK, working on this Khuk slowly but surely. GOing to make new CHkmak for it(and maybe new karda) but the chakma is what we're considering right now. Using a smaller file I have here, going to grind teeth off one side, leave them on other, going with classic( and more useful) chkama/file setup way they used to. Question is, on smooth side, leave it ferfectly flat, like it is now, or round it some. KNow there are others with morte chkma experience/knowledge than me, but I'm thinking it should be rounded a bit for burnishing inisde curve between cho and sweet spot. Obviously, this isn't the main user part for a Khuk, but with the 15" and unders esp, has seemed to me that a finer edge here, closer to handle, gives you a nice easiliy contorllable part for detail work(that's still a bit big for Karda). But if you put a fine edge there, and curve chakma as a I said, get a great little pull knife/whittler from that part of inside curve, esp. if you choke up to the cho(for once, a useful thing about cho creep, lets you get hand farther up for more control on little work like that)
