Changing Stropping Compound?
So, I decided to switch from finishing my edges with green compound to white compound. Is it viable to scrape off the green from my strop and rub in the white? Sounds like I'd be contaminating the white compound, any tips or techniques to do this, or do I have to get a new strop? :confused:
First, no need to get a new strop unless you want to have use of both compounds.
Without knowing specifically which white compound you're using, we can't say for sure what will happen. Here's why...
Green compound is 'usually' Chromium Oxide, at 0.5 microns. If your white compound is larger (higher grit number) then you'll do no damage at all putting it right over the green, even without removing the green first.
BUT... if the white compound you are using is finer than 0.5 mics, it becomes imperative that you remove ALL traces of the green. You can do that with lighter fluid, WD-40, Coleman Fuel, naphtha, or most any good solvent.
Stitchawl
Stitchawl
I get my compound from http://www.stropman.com/ so I'm not quite sure myself what grit I have, I'll try asking. And thanks!
Stropman's white compound is a larger grit size than their green. You should have no problem putting the white on. No worries about cross-contamination. Their white is, I believe, Aluminun Oxide, and 1-2 microns in size. MUCH larger than the green Chromium Oxide at 0.5 mic.
Stitchawl
Did you ever find out what Micron Stropman's White compound is? I've heard it can be anywhere from 1-10 microns. I hope not that vague and more along the lines of the above posters mention of 1-3 microns.
Anyone have more info on this? No info on Stropman's sight as to what micron/grit his white compound is. I was going to strop with white compound after using my spyderco ultra fine rod, which is 3 microns I believe. Now if white is in fact 1-3 microns I'm good to go, but if its 1-10 ill have to pass.
Particle size alone doesn't necessarily determine which will leave a 'finer' finish. Even at 10 microns, some 'white' compounds may not be anywhere near as aggressive as others at a smaller size, due to differences in hardness or particle shape. Some 'white' compounds are made as 'rouge' for jewelers (gold, silver, other soft metals), and those compounds will likely also be softer themselves (talc, tin oxide are a couple of 'white' compounds which are very soft).
I often use Simichrome polishing paste as a stropping compound, which uses pink aluminum oxide abrasive. It's particle size, as stated by the manufacturer, is in the neighborhood of ~9 microns or so, but it leaves a more highly polished finish than something like diamond at 6, or perhaps even 3 microns. That's just due to differences in hardness and shape of the particles.
Best way to see how each compares, is to try them. Don't have to put them on your 'good' strop to do this. Try them side-by-side on clean paper or identical pieces of something else (fabric, scrap leather, etc.). Take the time to strop your blade with each, and see how each performs. Try both on other steels as well; the abrasion resistance, alloy and hardness will all be factors in determining how a compound performs on a given steel. For example, green compound works GREAT on simpler steels like 1095 and some low/mid-range stainless like 420HC, 440A. But, the same green compound may be a disappointment on more wear-resistant steels like S30V.
(Edited to add: )
Some compounds are also 'friable', which means they start out at a given spec'd size, but break down to smaller particles with use (silicon carbide is known for this). So, effectively, they'll get around to producing a finer finish, even if they cut more aggressively at the start. Some aluminum oxide compounds fit in this category as well.
David
David, thank you for taking the time to post your comment. Very helpful information indeed!
With one worn out pair of jeans, and a few pieces of MDF or any flat pieces of wood, you can make at least a dozen strops unless you wear your jeans a lot longer than I wear mine.
No need to fool with cleaning a strop when its faster and easier to make another - or several, and try different compounds and see what you like best.
You can try several for less than a night at the movies with popcorn.
