Well , today i mount new bearings on my new flat platen for my new grinder.So i make several pictures how i do that .When i work on bearings i DON T want to use hammer because it is easy to damage something , especially if the wheels are from aluminum .Bearing should go straight out so it can not damage the bearing bed......impossible to that with hammer.This way i can pull out bearings without damage , say they are good and i need to work on wheels on lathe to refresh surface for example or to make new crown on tracking wheel.Same set up can be used to insert bearings ..............leave hammer for forging steel
It is clear from picture what was done , I hope ?
done ........
And here is my beast grinder , ready to grind some flat grinds
done ........
