- Dec 30, 2005
Bear with me I'm not a tech writer. Changed out the pb washers in my Bugout today. For some reaseon the Bugout gave me a problem. Maybe it was my glasses or I was in a hurry.
Cut to the chase. If you use a dab of glue, like school gule on one side of the washer applying to flace of blade it helps hold those things in place. Then carefully slide blade with washers in between the frame of the knife. Insert drill bit of approx. the same size as the pivot pin into hole for pin. Then align the pivot pin with the flat spot in the frame. With this all in place the pivot pin should follow the drill bit all the way through. You might have to jiggle the handle a bit but this works if you dont get in too big a hurry. Hope this helps. A third hand would help too. Dont forget to use a pan or bowel to put all those damn little screws in so you dont have to chase them.
