d.2.the.p
- Aug 30, 2011
The Chaparral I received unfortunately came with a good amount of grit in it. Though I was able to successfully remove it all with a lot of lubricant and cleaning, there still was the issue of the blade tang rubbing on the liner when deploying the blade with one hand. I found that through tightening the pivot screws, I was able to prevent the tang from rubbing. However, this is WAY too tight, and it opens and closes in almost a jerky kind of way (as I've found with any mid-lock that's been over-tightened). The action of the pivot itself is still smooth, but the tolerance is so tight that it prevents the blade from traveling in one smooth continuous motion. Does that make sense?
Has anyone else run into this that received a gritty Chaparral or one that rubs on the liners?
Also, I'd like to hear from the folks that received a Chaparral that was perfect right out of the box. Are the pivots similarly tight?
Thanks!
Thanks!
