I posted this in the Multitool forum in March, and received some great insight from some very helpful folks there (Thanks if your reading!), but I thought perhaps that those of you here might have some helpful input as well.
I just purchased a Leatherman Charge Ti and have to say I'm not completely overjoyed with it.
Issue #1: The main blade is incredibly tight and one-handed opening of that blade is almost painful, much worse than the serated blade and much harder to open than either of my Waves. I tried both WD-40 and 3-in-one oil on the joint, but it seemed to make the action even more stiff. I can see a little bit of browning on the part of the blade than contacts the bushings, which are bronze. It looks like a bit of corrosion there too, but not too bad. I did treat the joint with mineral oil, which freed it up a little bit, but not that much, still too tight in my opinion.
Issue #2: I've noticed that the liner locks on the serrated blade, saw, and file each only engage partially. I'm thinking this could become dangerous. Any suggestions on how to tighten them up?
I think I'll keep this tool if I can just get the opening action to be nice and smooth on that main blade. The CM154 is incredibly sharp. So here's the question, what else can I try to free up the action on the main blade? I'm trying to keep the tool safe to use in food prep if necessary while camping...thus my switching to mineral oil and trying not to use stronger lubricants. But if that's what it takes...
So here are my issues: something too tight (main blade) and something too loose (liner locks). Thanks for any and all suggestions.
-Tim
-Tim
