Charge wire stripper question
shootist16
knife law moderator
Moderator
is the wire stripper on your charge sharp? Mine is just a dull V. The stripper on my other multitools, including my wave, are sharp. Is mine defective or all they all this way?
My wire stripper on my new Charge is pretty sharp-at least for a wire stripper.
My only complaint on the whole tool at this early juncture is that the clip oint blade opens stiffly. I think that is is the liner lock that is putting pressure on it. Hope it will loosen up a little.
Overall, my first impression is that this is a very well built multi-tool.
Daniel
Mine must be screwed up. Its not sharp at all. The notch isnt angled or anything just a dull V shape.
mine is quite sharp as well. My can opener is quite dull from the tip half way down the edge, but nothing a sharpening stone can't fix. For opening cans it is fine but i use it for a couple other things as well which require it to be a bit sharper.
Don't worry about the blade opening, with a bit of use they both become very smooth. Make sure you add a bit of oil in the pivots and that will make them even smoother.
