The best article I've read on this is under the following URL:
http://www.mhcable.com/~yocraft/sosak/convex.htm
There's a downside to stropping however - your knife won't look the same as when you first bought it...
The reason for this is that when you strop, you have to lay the blade parallel to the surface youre stropping on (e.g. 200 grit sand paper!). This, of course, takes away material from the entire surface of the blade, and not only from the edge of it ergo youre scratching up the entire blade.
Like the article says, however, thats the idea behind effective stropping the entire blade reduces itself, and not just the edge. This means that at the end of the day, a convex edge will cut as well 10 years down the line as on the first day you bought it.
The trade off is once again - that sandpaper really scratches the fine polish on an expensive blade (e.g. on an H1, or an S1), not to mention the coating on tactical blades that have convex edges (i.e. Busse, Chris Reeve, Entrek etc.). This having been said, however, my experience (at least on fine polished blades like the H1) is that after having used sand paper (on top of two mouse pads) on the blade, I finish it up with a loaded, leather strop, which then polishes it off well enough so as to take away most of the nasty scratches, leaving a very acceptable finish to an extremely sharp blade. What I really mean is that the stropped knife still looks good...
This is my experience with stropping I've only obtained results with this method. If someone else can give me a useful tip re coated blades, however, Id appreciate it. For the record, I havent stropped any of my coated tactical blades yet, as I dont know how the heck theyre going to look after having been dragged over hard core sandpaper. Again, if anyone can give me a tip here, Id appreciate it! Best
