ashwinearl
- Nov 9, 2006
I have been using some cheap digital calipers for marking grind lines. The calipers are great all around for shop tasks and measuring pins and do ok for marking the initial grind lines. But the lines always seem to go out of parallel closer to the tip.
I've wanted a height gauge but can justify the expense for a nice one. I've seen these cheap ones ($17-$30) an wondering if anyone has used one for this specific task. I have not tried the drill bit technique. I sort of like calculating desired thickness, like 0.030" subtracted from the blade thickness divided by two and set that exact amount on the caliper...not that I ever even come close to grinding to it, but it is the thought that counts.
