- May 19, 2007
So, I've been away for a while, but I suspect that the love for good 550 cord has not dwindled, (unless there is a source for cheap 4mm spectra I don't know about). With that in mind, I have been playing around with a chunk of climbers 1 inch tube webbing, about a yard and a half, just to see how I could use it. So far the cons are that it is bulky for any given length, and it's relatively high cost, but that is about it. Tube webbing is incredibly strong, the stuff I have is rated to 17Kn or 4000lbs, which is fairly impressive. It is slick, so sliding it around is fairly easy, but it holds knots in itself very well, and can be used with some hitches, depending on the application. Since it is a tube it can be used to sheath other ropes/cords, as a handle cover material, and as a more comfortable gear repair option for straps.
So far I've used the same section as a sleeve guard while shooting my compound outdoors. Then when it warmed up and I took off my jacket, I made a quick loop, and had a bow sling. Add a couple small carabiners and you could have a carry yoke. obviously it is a good choice for hanging hammocks from trees, and other applications where you want to distribute weight.
Anyone else have any uses for this stuff?
