Depending on the size/width of the blades you're re-bevelling, the lower spec'd limits of guided clamps may not be relevant anyway. For example, the Lansky's marked angle settings are only accurate as measured at the immediate front edge of the clamp. Any blade edge that extends beyond it will sharpen up at an angle lower than the marked setting used. I measured & used some trig calculations to figure this out, when using my Lansky clamp to re-bevel the main spear blade on a Victorinox SAK. The edge of the blade extended approximately 3/8" beyond the clamp's front edge, and the resulting angle when using the '17' slot on the clamp actually turned out to be just below 15° per side. Very wide blades, like large kitchen/chef's knives, will sharpen up at angles much, much lower.
Having said the above, I don't know if any clamped setup will go as low as 10°/side on more typically-sized EDC blades. Some clamps may get somewhat lower if used in conjunction with a bench stone, instead of with the guided-rod hones. Used with a bench stone, by sliding the clamp along the tabletop surface next to the stone, the clamp is more out of the way if using a diagonally-oriented sharpening stroke. That sometimes can allow a lower sharpening angle, depending only on the thickness of the front portion of the clamp, which may otherwise get in the way. You can elevate the stone as needed, in relation to the clamp, to get the angle as low as possible without actually grinding against the clamp itself.
BTW, I have re-bevelled many blades of ~3/4"-1" width using the lowest marked slot on my Lansky and/or Gatco clamped systems. I didn't measure the actual resulting angles, but if the bevel widths are any indication (~1/8" or so on a Buck 110-sized blade), I'd bet most of them were down around 12°/side or maybe a little lower. The lasting impression left is that these systems will go quite lower than what the marked settings imply, depending on blade width.
David
