It doesn't happen too often, but every once in awhile I discover a bullet or shotgun shell that's either too damaged, or improperly loaded, to use.
A couple of days ago, I opened what I thought was a brand new box of 3" 00 buckshot shells, and I found one that looked like someone had attempted to load it, from the magazine, into a shotgun that has a 2 3/4" chamber. The brass is indented badly, on one side, and there are two gouges in the brass that appear to have been caused by the extractor trying to pull the stuck shell loose. I don't know if this particular shotgun shell is capable of being chambered, it's so badly damaged, but I don't want to hurt my shotgun, or me, by trying to chamber it, and then firing it. So far I've just marked the box that contains the bad shell, so that I'll not load it, but I should instead throw it away so that it's totally safe...and maybe I should dissect it, first?
The second piece of bad ammunition I've found, also in a new box of ammunition, was a 9mm cartridge that was missing it's primer along with the "fire hole" that connects the primer pocket to the gunpowder inside the casing. Basically, this is a bullet that would only fire if you threw it into a fire. Granted, this is target ammunition, and shouldn't be used for self defense, but it wouldn't be good to be in a surprise self defense situation, and that bogus bullet was chambered, expected to be fired!
It's one thing to have ammunition that fails by surprise, but quite another to have ammunition that looks faulty on examination, and to use it. So, I would recommend looking at your ammunition before loading so that you can prevent a mishap/misfire and/or personal injury.
Maybe that's why ammunition receipts at Wal*Mart state "All ammunition sales are final."??
GeoThorn
GeoThorn
