- Feb 17, 2016
Has any of you ever tried to remove some ridges on a checkering file to make thumb serrations wider on the spine of the knife? If so would you share your method? Thanks in advance for your help.
Hey Andrew, Can you give me a link to that 10 lpi checkering file?
I would like to know where those 10 lpi files come from, too. I could only find 20 lpi.
Tim
Stacy's suggestion is the best course of action. You're not supposed to use checkering files for anything other than laying out the pattern anyway. They set your lines so you have something to follow with a needle file, and you use the needle file to bring the points up.
+1 on that. I can only find as low as 20lpi.
Tim
Same here I bought mine from Brownells 20 LPI. I never seen less than that.
This place is going to be stocking 10LPI, I believe. They also stock the rest of the sizes. I use a 35-40 LPI(#1), and it looks/works great.
I don't like serrations to look like sawteeth.
http://www.boggstool.com/
Their toll free# is, 1-800-547-5244. They are in Paramount, California.
They sell checkering files for $24.50, and 25.50, depending on LPI.
They also resharpen dull checkering files for $5.00, and they come out sharper than new. They sharpen regular files, end mills, taps, carbide rotary files, etc.
Call Mark and get a catalog, he'll send you some coupons good for two file resharpenings at N/C.
Edited to add; Here is some normenclature on checkering files.
00 = 20LPI
0 = 30LPI
1 = 40LPI
4 = 75LPI
Hope this helps.![]()
