Checkering, texturing G-10 at home.
Not sure if this is a right section to post this but here we go.
I have Hogue G-10 grips on my handgun that have a smooth finish that is not ideal for a sure grip for a stressful situation.
I was wondering if it was possible to add some texture to them using something as a dremel. I was thinking may be just do some kind of a dot-cone cavity pattern, by just drilling with a tiny unibit into the surface.
What do you think? Has anyone done anything similar to the g-10 on their knives or guns? Pictures would be appreciated.
P.S. I know there are companies that specialize in checkering but their price is way out my budget and well above the cost of the grips.
I wasn't aware that Hogue made G 10 grips. Can you post picture?
They started not so long ago, they make several finishes but I was only able to find smooth because everything else was on backorder.
If I remeber right, I saw the pictures of different checkering they make on the Sig forums.
If you have a steady hand and patience, buying and then of course using a checkering file would do the trick. Should you choose to travel this route, do yourself a favor and use some manner of file guide. Nothing worse than making a bad pass and carving through the grooves you already made.
I wouldn't recommend using a dremel personally, but then again, I'm opposed to letting a dremel near my knives/guns/objects.
Depending on the cost of the project you might want to practice on some in-expensive raw G-10 sheets. They can be ordered fairly cheap.
A trick I have used on small jobs is to secure everything and stack up a bunch of new cutting discs on a Dremel tool. Separate each disc with a washer. Doing something as big as a pistol grip is going to take some seriously steady hands or it will look like poo.
A random drilling pattern may be easier to pull off. Get a marker and draw it out first and see if you can live with the pattern.
Dremel also makes a new tool that is essentially a mini router, that could do some neat stuff I bet...but by the time you buy all these tools and tear up a few practice pieces (and potentially botch a set of grips)...you might be best served sending them to a pro? Just a thought. I love DIY stuff for the satisfaction it gives...but unless I can afford (money and mentally) to replace whatever I am working on...
You can easily stipple them with an electric engraving pencil.
G 10 dust is really bad stuff to breathe, BTW.
Thanks all. I will try it on my bark river knife handles first, hope i don't screw it up too badly.
I'm gonna wear safety glasses and dust mask.
Well, not to ask you to spend any more money, but If you have one of the newer Dremels you can purchase the Dremel Drill Press attachment. Mark out a pattern for drilling the new dimples, secure the grips, and drill out areas of similar relative height. Then move onto the other areas, etc. Would look and feel a bit more professional with just a bit more time and money invested.
Good luck! Please post up the results.
Here are a few I've done using a Dremel.
This is not G-10, but is buffalo horn, made from scale blanks, using the Dremel, some files and sandpaper, for most of the work.
The Boker knife was completely worked over and changed a lot, besides the scales. Wanted to make it look like it had been to hell and back.
This is not G-10 but celluloid; I made these scales almost entirely using the Dremel.
Practice first on other materials, not necessarily G-10, but any solid plastic will do. Or go at it on a piece of wood. The skills you wish to develop do not require G-10 to develop them.
It's also a good idea to have an extra pair of grips in case things don't turn out as you like. Good luck!
