T
timfish
I think you mean that your edge is recurved, so it touches the board near your hand, and towards the tip, but not in between. You can do a search here (or on Google images with the word “recurve” to check if this is the right description.
Also do a search for the “two inch mark” with reference to blade grinding. This is when you get an area of deeper scratches a belt’s width in front of your plunge line, where the belt tends to linger longer. If you don’t correct for this, the result can be that the blade is ground thinner in this middle area, if you then sharpen with something that cannot span the thin area, and you take even material off the whole blade when sharpening, you get that concave, recurve shape edge.
There are experts here. I am not. However, the way I have most success keeping straight edges is to tip the blade just a little when I am grinding the plunges, more pressure at the plunge so the other side of the belt is not really cutting while I work the plunge.
A good tip, sharpen roughly, before you finish grinding. It really helps to show how edge thickness is progressing. I also use callipers so I can find relative thin/thick areas along the blade.
While shifting pressure closer to edge or spine to adjust the bevel is useful, it can make finishing and getting even bevels harder if used too much. With kitchen knives, concentrate on getting a really flat bevel and keeping it flat through all grits.
Chris
