I did google search, which is how I came up with my specific questions at the bottom of the post. I'm trying to make my posts more concise, so here goes:
- belt grinding causes heat due to friction.
- the thinner the cross-section, the easier it is to overheat metal due to the less thermal mass.
- the thinnest part of a blade is at the apex, where the cross section is only a couple of microns across.
- temper occurs at between 350 and 500 degrees for many common types of steel.
- belt sanding can allegedly get the apex above the tempering temperature without the rest of the knife being noticeably warm.
- using ice water to cool the blade seems like a good idea to prevent the blade from overheating.
I started sharpening two knives at a time, leaving one in the ice bath while sharpening the other to keep both from overheating at the edge.
Questions:
1. is there any drawback to letting the blade sit in ice water for a while before grinding? i.e. micro-fracturing of the metal due to thermal stress... etc.
2. is this much ado about nothing? I have read that many knife makes use chiller platens and wet belt grinding systems, so there is obviously a subset of makers that think that temperature control is important.
Questions:
