- Jun 26, 2019
Hi,
My first knife making attempt is a chinese vegetable knife/cleaver in CPM M4. It is a thin knife about .060 at spine and .010 behind the edge. The edge profile is nearly straight with very little belly. Unfortunately I have several spots where the edge has some low spots and some high spots that prevent it from contacting the cutting surface smoothly along the length of the blade when I cut. It leaves a bit of uncut food unless I do a push or draw slicing cut.
I think this is because I didn't have the behind the edge thickness the same along the length of the blade. My theory is that I had some spots that got thinner behind the edge and when I put the edge bevel on and sharpened it the thin spots ground out to an apex sooner and then turned into little hollows. Does this seem right?
How should I fix it. I'm not skilled, this is the first knife I've attempted. I have a 2x42 grinder. I did the edge bevel and sharpening with a Hapstone guided system holding 3" x 8" atoma plate. After discovering the problem I went back to the hapstone with the atoma 140 and attempted to use it to grind everything straight and it keeps creating these hollows that don't contact the cutting surface.
Here is a pic of it against a flat cutting board. Notice the wavy edge and alternating hollow spots and points of contact.
IMG_0898 by Loren Jones, on Flickr
Here are some other pics of the knife and of the little wharncliffe I made from the handle cutout that I use as a package and letter opener.
IMG_0884 by Loren Jones, on Flickr
IMG_0883 by Loren Jones, on Flickr
IMG_0886 by Loren Jones, on Flickr
IMG_0904 by Loren Jones, on Flickr
IMG_0898 by Loren Jones, on FlickrHere are some other pics of the knife and of the little wharncliffe I made from the handle cutout that I use as a package and letter opener.
