Some time ago I bought a Chinese made clone of a Victorinox Tinker, sold under the Truper brand which is a well known tool distributor in Mexico, I was impressed with how good it was for about $4 US.
Well, a guy at work was selling stuff from a Truper catalog and they have a clone of a Victorinox Huntsman for about $10 US, I just had to get it, I've had it for a couple of weeks now, it's OK but definitely not as close to a SAK as the Tinker clone, I guess more tools are more complicated and harder to make a good copy. Here are some comments and pictures:
What I received was not a clone of the Huntsman, it was larger at 5 springs wide and had three more tools, steel feels similar to the real thing, easy to sharpen, edge holding is fair, general fit and finish close to what I'd expect from a real SAK, somewhat over polished, springs on the weak side, one spring is very weak.
Comments on each tool:
Main blade.- Good but much thinner than the real SAK blade, machined down to make space for the small blade on the same spring.
Small blade.- quite good, if it was put in a SAK I would not know the difference.
Saw.- well made though not as sharp as the real one, feels like a SAK saw that's worn a little, spring is weak.
Scissors.- Not as well finished as SAK scissors, but cuts just as well.
Phillips driver.- about the size of a #1 Phillips, not so good, over polished and slips out of screws, I could probably make it good by sharpening it but wont bother for now.
Magnifier.- not good, smaller than the real one because of the plastic thing used to keep it in place, when focused in the center, the edges are blurred.
Screwdriver/Cap lifter.- Good, feels as good as the real one but the spring is very weak to the point of feeling dangerous, like it will close in use.
Can opener/screwdriver tip.- Same comment as with the screwdriver/cap lifter, well made but in the same weak spring.
Corkscrew.- good but a little bit shorter than the real one, will not hold the Vic accessory eyeglass screwdriver.
Reamer.- not sharp at all, could be fixed with some work, it is in the same weak spring as the screwdriver.
Hook.- Good, feels just like a SAK hook.
Small screwdriver on back.- Good. not as well finished as the real one but seems like will work fine.
Tweezers and Toothpick.- as good as the real thing, the toothpick was loose in the handle slot but a little pinching with pliers fixed that.
Luis
Luis
