CHINOOK 3 - question
Dear all,
I bought a Chinook 3 a few years ago.
The Chinook 4 already existed, but I had a preference for the # 3 and had managed to buy a new one among the last ones left for sale.
I didn't use it, maybe a bit desappointed, because the knife has a little vertical blade play, very few but absolutely noticeable.
Today I felt like to take it out of the drawer and my question is :
Is it normal that this model, the Chinook 3, has a little bit of vertical blade play?
Thank you very much for your opinion
There was a thread about some back lock folders having vertical blade play on spyderco forums recently, but I don't have a Chinook 3, nor any of my lock-backs have blade play (knock on wood). If that is what it is, I think it is nothing to worry about.
No, not "normal" for any Spyderco.
If it's a "problem," I'd send it back to Spyderco to see if they can fix it.
If you sent it in when you bought it, you might have been able to get a free replacement but not sure this is still possible since the Chinoook 3 is no longer made but they might still give you a Chinook 4 as a replacement after the passage of "a few years" time.
PM Sal here to see what he has to say about it.
If you sent it in when you bought it, you might have been able to get a free replacement but not sure this is still possible since the Chinoook 3 is no longer made (but they may still give you a Chinook 4 as a replacement after the passage of "a few years" time.
Thank you Sgt1372.
It's true that I should have sent it back to the dealer.
The dealer is an honest business in Luxembourg from which I bought some knives. But I knew that the model Chinook #3 was at the end of its life, and became difficult to find. And it was a #3 that I wanted, it was the last one in stock in the shop.
So, it's the reason why I didn't sent it back to the dealer, I kept it but didn't use it, upset because of this small vertical play (it is like new).
The vertical play is moticeable when you force a bit on the knife (for example to cut a pizza whose paste has been a little overcooked). So not an exceptionnal force !
thank you for having answered my question,it's not that bad, just a little disappointment. The knife is beautifull.
Regards
Brice
It shouldn't have noticeable blade play -- mine doesn't. But maybe it's assembled too loose (pivot or lock screws). On the bright side, the Chinook 3 can be disassembled. Might want to try. Note that the Pivot screw can only be unscrewed from one side. I forgot which side though, unfortunately.
Roland.
A disappointment for sure but I don't see any problem with its usage. Have seen much worse problems on here. IF you feel comfortable d'assy is something you could try as noted earlier.
a very small amount can be normal, but if it really bothers you sell it here or on ebay and then look for a new one with no play at all, they pop on ebay all the time and there are currently a few available as we speak for reasonable prices
