brownie0486 said:Mines the same way.
I thought perhaps it was in the heat treat that it ocurred. I like it actually.
Brownie
Mine neither. It does sound like polishing rouge or something similar.Dirk said:Could be left over buffing compound. Niether of mine have it.
Joyce Laituri said:Hi Madfast,
The maroon coloring is likely a combo of the heat treat and the heat from the laser cutter. It doesn't affect the performance on the blade's steel. Think of it this way.... if youre ever in a crowd of Chinook carriers and you all take your knives out, you'll be able to tell which one is yours, rather comparable to a small beauty mark...LOL
Joyce @ Spyderco
brownshoe said:If it's marroon in color and it's not rouge, it's rust. Oxidized iron is red. My spyders get discolored in the hole, it looks reddish and comes off with flitz, just like rust. I've never received a new spyder with rust in the hole.
TOMBSTONE said:Actually,it is neither rouge or rust.Some of mine have it and some don't.Some are more noticable,than others.I have cleaned with brass barrel brush and solvents and does not seems to affect the discoloration.This leads me to believe that it goes deeper than the very top surface.If it is that bothersome to some,you may try lightly sanding and polishing the hole.That may or may not do the trick.Depends how deep the heat discoloration goes.I
personally wouldn't bother to be to anal about it.
p.s. By the way my discoloration is more light red or orange in color.
