Chinook II sharpening
Anyone else have trouble with the last bit of the chinook blade, about half an inch from the tip? I use a sharpmaker and the rest of the blade is shaving sharp but I can't seem to get that half inch in line with the rest of it. I used the sharpmaker, stropped it its just that last half inch.
Use a permanent marker and coat the edge, make a pass down the rods and see where your grinding. The key is to not follow the curve with a turning motion but by raising the handle.
+1 on that.
I couldn't get the edge right either, so I changed it up a bit. You almost have to pull the knife in a curve, moving your elbow and wrist.
I don't have a sharpmaker so I can't show you on that. I am stropping the knife in the video but the same technique applies with all blades and sharpeners. The knife I am stropping has a similar up-sweep to the blade and you will notice that it looks like I am not hitting the right angle with that motion, but I am. I start choil to tip and then tip to choil just to show the motions. Hope this helps.
http://s284.photobucket.com/albums/ll20/knifenut1013/?action=view&current=Picture322.flv
