Originally posted by fulloflead
I just wish the grind was on the OTHER side like it should be for right-handers. According to Emerson's site, the choice was cosmetic.
But then...
my Snody is the same way, so who am I to question?
You are a KNIFE BUYER, and a KNIFE USER, that's who you are to question. And your line of thinking is about exactly what I went through about 4-5 years ago.
I'm with Keith on this, all the way.
You can learn to sharpen a chisel ground, so that argument doesn't hold water. (I've never gotten a sharper edge on a tool than on my FIRST TRY with a jig and water stones on a wood hand plane blade, which is chisel ground ... truly scary, cuts hair above the arm, super jumpin A2 blade, on water stones).
Ernie's comparison of a knife to a chisel is ridiculous, and all an attempt at analogous marketing hype. Totally different tools. Chisels are MORE useful with a chisel grind (you need a flat side to, e.g., chisel out a mortise, or skim glue off of a flat board), whereas a chisel ground knife is LESS useful than a symmetrically ground knife. And Ernie DOES grind on the wrong side for 90% of the (right-handed) population. Try one of his knives for utility work and you'll know... I did, I know, I sold. (how do you say that in Latin?). Bingo... his admission is that it's about aesthetics, if you 1/2 way read between lines.
I tolerate chisel grinds only on knives that are exclusively for self defense. For utility work, they are inferior. Period.
One other spot: a chisel ground chef's knife with a very shallow angle of grind can be useful for pushing the freshly chopped food away from the blade a bit as you chop. Some Japanese chef's knives are set up this way. I don't own one, but am sure it would work fine if ground for a right hander (which I am).
Chisel grinds may be easier for a maker to grind, only one side, so don't have to grind symmetrically or evenly in plunges, etc.
As to drag, a flat ground knife is going to be so close to a chisel ground in terms of drag, I can't imagine you'd notice the difference in use unless you set up experiments and measured with equipment. Edge sharpness and edge geometry would dominate.
In fact, for hard use, I can make the argument that a chisel ground blade would be more likely to encounter lateral stresses (asymmetrical blade) in chopping, if say, you hit a knot, and therefore would be more likely to chip out if all else was equal (edge angle, heat treat, material, etc). The "more cross sectional mass" thing is only on one side.
Now, if RJ Martin chimes in here and tells me I'm full of... uh ... lead
on one of these points, then I'll listen and try to reformulate my hardening of the attitude about chisel ground blades.
Chisel ground blades do look more "appropriate", more "traditional" on Japanese knives, I'll give them that. You can't argue tradition, it's based on history. I don't hate the way they look, just dislike them for utility.
Here is another of Ernie's quotes from his web site:
Why do you put the chisel on the front or left side of the blade?
This is an Emerson signature. Being the knifemaker who brought the chisel grind to worldwide recognition, we are often asked; Why do you put the grind on the opposite side of a traditional Japanese Chef's knife? The answer is simple....We are not making chef's knives. Our knives are hard knives meant for hard users. We do not cut many tomatoes. Our tests and those of a major government agency determined that there was no difference between right and left side grinds for use as a tool or weapon. The left side was chosen for purposes of visual cue and reference
As a weapon? Probably true enough. As a tool? BS. "Visual Cue and Reference"? Triumph of knife photogenics and marketing over utility. "We do not cut many tomatoes"? Marketing appeal to armchair commando's.
Ok... that felt good ... a rant early in the day, and now off to enjoy :grumpy: the installation of some more drywall.
This topic has been ranted about en masse in the past... try the search engine for a few old lively debates. Full of opinion, just as you'd hope for.
