- Jul 16, 2012
Hello all,
I'm needing to touch up my cqc7. I'm not new to sharpening knives, however this will be my first attempt at sharpening a chisel grind.
I don't want to re profile the knife so I won't be using my lanskey, instead I'll be using my sharp maker.
So once I set my sharp maker up, do I only use one side as opposed to alternating strokes side to side? Do I progress through my stones (medium, fine, ultra fine) with only hitting the edge side?
If this is the correct way, I'm assuming a burr will form on the flat side. How would I remove that? Stroking the flat side only over and over on the uf rods.
Then follow with a strop to the edge side?
If this is all wrong as far as sharpening the chisel grind, by all means please correct me. Thanks
