- Sep 13, 2006
What are the pro's and con's?
That's kinda what I was wondering. I hate to take a chance on a 200 or so dollar knife and not like the grind.
I've got a couple of Emerson's they don't hold an edge well for me. I second FFG.
I would agree, sharpening is no more easy or difficult with a CG. What I did find is that I can achieve a much sharper edge for a really precise cut. I do the controlling on the cut, not the tool. So IMO, the tool is part of it, the fine motor skill is another. The veering does occur if you are push cutting through stuff, but can be easily corrected by slicing instead.I tried different chisel ground knives (and a couple with chisel edges), and really didn't like any of them. It's fine for SD knives, or if you don't mind losing some precision in your cuts (or if you use chisel ground kitchen knives for a specific task); but for EDC and work knives it didn't perform well for me. It's difficult to make a straight long cut the blade tends to veer off to one side.
I found sharpening to be more or less the same as with regular "V" ground knives, perhaps a bit faster since you only really sharpen one side and then remove the burr on the other. Not a huge advantage.
That's because they're tempered soft.
Chisel grinds cut great on small, thin knives. I don't like them for chopping, batoning, etc.
If you're good at sharpening, it's all the same. If you're not good at sharpening, it's a little easier.
Throw a reverse edge bevel on it and the "drifting cut" disappears.
I also don't believe in left vs right handed grinds, unless you're making very low angle cuts.
