Chisel Grind?
gscreely
I am doing a run of 6.5" chefs knives .065" stock, super-thin bte geometry and have been experimenting with different grinds. I am really leaning towards a chisel grind, I know they are polarizing, but I think it could really distinctive feature of the blade for the folks that love chisel grinds. What do you guys think?
Great looking knife. I like chisel grinds on knives, but that may be because I can sharpen them easily.
Do you cook? Can you slice an onion? A symmetrically sharpened blade will cut straight down through an onion. A chisel grind will veer to one side and produce a thin/fat slice. And might veer close to your fingers.
A Usuba is typically a chisel grind.
You should post this in the Buck forum. Lots of people with experience with a chisel grind in there since that’s all Buck is capable of producing these days.
That's the main appeal, yeah. When you want something that's dead simple and always sharp, you want a chisel grind. You don't even have to think about it. Even better if it's a sheep's foot. The easiest thing to sharpen in the world is a chisel ground sheep's foot knife.
I cook a lot. I would say that issue is overstated, but not without merit.
I had an Emerson CQC-7 custom with chisel grind and I loved it. I gave it to a deserving soul but I do love a good chisel grind.
As a lefty, I'm not a fan of chisel grinds in large part because they are inevitably ground on the wrong side of the knife. Also just never met one that I really preferred over a v grind. Just throwing my penny's worth out there.
You need a left handed knife.
I am not a fan of chisel ground knives for the kitchen. Pocket knife or EDC type blade, they can work great! I am not sure how a low chisel grind would perform in taller/harder ingredients since most of the knife will be at the .065" thick? It may make for a lot of sticktion, too and more friction in the cut? For a knife for proteins/softer items, it may be OK (like a Honesuki, Deba, Yanagiba, etc), but for general use, something more symetrically ground (preferably convex or S grind) and farther up the blade would be my choice.
Yes, Usuba are chisel ground, but they have the ura side ground with a slight concave and the chisel grind is usually convex. They can work well, but need adjusting your technique and are more of a purpose built knife/shape than a general purpose chefs knife?
I would try your knife in a variety of foods and see how it goes? When I grind kitchen knives, I do a lot of testing with a variety of ingredients to see how the grind performs while I am grinding the blade.
I have a Mioroshi Deba and it’s really nice for trimming meat and taking chickens/fishes apart. I mostly use it off the cutting board but it also does fine for small veggies.
The only things it doesn’t do well is cut tough material (bone) and make even-thickness slices of bigger veggies.
If you’re doing a batch, why not do 1/2 of each (same handle materials/styles for std/chisel grinds) and see which ones sell fastest?
I'm left handed. I have a collection of scissors and shears. All right handed. It is difficult and very uncomfortable for me to use a left handed scissor. That seems to be true also for other left handed people. We have spent a lifetime using right handed tools. It's built in to our muscle memory.
I expect that this is equally true for knives. We've spent a lifetime compensating for less than optimum tool set up to get equivalent results. We've spent a lifetime using right handed knives. It's built into the muscle memory now. Most of us couldn't use a left handed knife well. Especially using a set of knives, some left, some right. That said, there are probably knives and edges that are easier or more difficult for a left handed person to use. A chisel grind edge might be one of those.
