Hi,
I have been told (and read) that chisel-ground edges are potentially sharper than conventional edges. My only experience (other than exacto knives) is with knives that were so bad that the grind was irrelevant. Is the idea that the one side is ground to a low angle (maybe 20) so that the inclusive angle is lower than the typical 30-40 inclusive that we are used to?
I think the idea is chit-chat
Japanese knives are commonly thinner at the edge and lower angles, and some of them have chisel/asymmetric edges ...
I have also read
Chisel grinds are stronger and that its not true as they're unbalanced (steering, unbalanced lateral loads)
When sharpening, is it just sharpening to burr, refining, and stropping the ground side and stropping the flat side?
FWIW, I'm interested in these mostly for kitchen use.
Yup, sharpen like a regular knife
you can see some wood workers just raise a burr, then strop to remove burr
But for domestic kitchen knives I don't really see the
appeal
at least when it comes to small paring knives which come with chisel ground,
I guess it helps to have the apple/potato peel go off to the side more forcefully,
but I've never found that too be important.
Also they're all
left handed chisel grind ,
ok if you peel stuff toward yourself,
but if you cut the regular way the steering is in the wrong direction for right handed use .
a regular/balanced blade doesn't have steering/bias so use as you like with equal comfort
there might be some advantage for chopping veggies ... or sushi or such? ... but plenty french/european style chef knives do that kind of work without problems and they're not chisel ground ... choices choices
