A double ground knife can have the same "relative" geometry as the chisel ground knife, so a chisel ground knif eisn't inherently stronger or sharper. "Typically", chisel ground folders sem sharper because they are ground at something like under 30 degrees and given an edge bevel of around 30 degrees, which is a lower angle than your average knife (40ish degrees).
A chisel groudn knife with no or onyl a slight secondary bevel won't curve to one side as much (or at all).
I actually find them easier to sharpen, if you do them "properly". You sharpen the bevel on your medium stone, raising a burr, then you put the flat back side on your finest hone and to strokes perpendicular to the edge, cutting off the burr. As you can imagine, the finish on the back of the knife will no longer be even or all that pretty, but it will make the knife work better! You then use your fine hone on the bevel for a few strokes, then one or 2 on the back, repeat a few times, then you do alternating strokes a few times (1 on bevel, 1 on back), then you are done.
