Hi,
Can someone explain the différences between the chitlange and sirupati kukri in use, handling etc ?
Or are there better alternatives for an allrounder kukri ?
Regards,
Frank Michiels
Probably not much difference, since the blade profiles and weight distributions are fairly similar. The chitlangi is fancier and has those beautiful fullers on both sides, but I doubt it affects use or handling.
If you've been looking mainly at the HI web site, be aware that these blades come in a variety of weights and lengths, not just the one or two most common options displayed at the web site. Follow Yangdu's DOTD postings on this subforum to see some of the possiblities. You can use the search box in the upper right hand corner to find previous offerings of those models, with specs and pictures.
As for alternatives, many forumites have their favorites, but the model that has been recommended for all-around use by Pala (the owner of HI in Nepal) is the Gelbu Special. It also has a blade profile not much different than the chitlangi and sirupati, but is perhaps a little more robust. However, since these are hand-forged blades, any of these models might be a little beefier than any other in a particular instance.
Some people might recommend one of the heavy choppers, such as the Ang Khola, the M43, the Ganga Ram, or the WWII model. Of these, the only one that can truly be considered an all-around khukuri is the WWII. The others tend to be thicker and heavier than you really need for most tasks, although even here there are exceptions. Some of the 15" models (that's overall length) lately have been lighter weight than in the past. In my opinion, weight is more important than length, and a few ounces can make a huge difference in use. Of course it also depends on your strength and fitness level.
The least expensive all-arounder would be the KLVUK, which makes a great first khukuri. Again, use the search facility to find out about these. The KLVUK is not available at the HI web site, only here in DOTDs or by emailing Yangdu.
