since we are on choils....is it pronounced "coil" or "chur-oil"?
Do these features cause stress risers?
In the book "How to make knives" Bob Loveless says he uses the photo etch to mark his name on his blades, instead of stamping the blades, because stamping the blade could a create stress riser, or weakened area.
Choil notches, and singular spine notches, similar to Fisk's Sendero.. seems like there might also be a trade off in integrity/strength, for cosmetic purposes. Just throwing it out to the wolves, for some discussion.
Thanks,
David
Neither, it's pronounced ch (as in chore) - oil (as in coil).
Not sure about the stress riser thing, but I would think that plunges would be every bit as likely to cause weakened areas as would any of the other things mentioned.
Yes - it might not be material if the knife was properly normalized / heat treated, but all things being equal, a sharp notch, choil cut, raised edge, etc, etc, creates more stress points. (Not sure the stamped name is meanigful though.)
What I don't know is whether normalizing or sphereoidizing the steel would remove them 100%.
My point is that the features (maker's stamp, spine notches etc.) described in the initial post would be insignificant, as other factors that would most likely contribute to failure first under EXTREME duress.
A sharp choil is a stress riser, and can multiply the stresses at that point by many times what the stress would be in the bulk blade material, but is it honestly a problem? Even the poorest quality steel's strength is measured in thousands of pounds per square inch. Aside from blades with very small cross-sections, no person should have the strength to break a knife in the direction where the choil creates a stress riser.
The drop in cross sectional area formed by the plunges would cause an area that is likely to fail in shear stress, rather than normal stress like the choil would experience. The plunge is still a potential weak spot, but as I stated in the above post, not likely to be a point of failure under the forces of a human.
So, I take it there is no significant weakness caused by a maker's stamp? .. the reading in "How to make knives", indicated that Loveless thought it created a stress riser to stamp a blade. (or maybe i read it wrong?)
David
David
