- Sep 28, 2005
Since I am asking the question then I will answer first. Leave em!!!! I can see no reason for them as they reduce the useable amount of blade. The most often used excuse that I hear is that it allows one to choke up on the blade for detailed uses. This seems like an excuse for less than perfect handle design- if the handle is designed properly then why would you need the choil as the handle will allow closer use of the blade. The only exception that I can see is in cases like the Spyderco Native where the blade is used as part of the handle.
Any comments??
Any comments??
