So I have two Oxhead hatchet heads I'm rehanging right now. As I was hanging them, I noticed, that after tapering the handle to fit the bottom of the eye, it was getting stuck later on in the eye, which I found odd, since I thought, that the eye of an axe becomes wider towards the top. I then looked at the eye and noticed, that there is a prominent high point in the middle of the eye. I'm concerned about this, since it makes me feel like I have to remove more wood than is needed just to fit through this narrow part. Also, I took the length and width measurements from top and bottom of the eye of both heads and there is no taper.
Is this common or is it just a bad design from factory? The head became loose already once after hanging it, makes me wonder if this was a part of the problem. The obvious solution would be to file down the high points, I guess?
