My primary work knife is called a Kobito, made by Aesculap Medical. It is basically a reusable x-acto or scalpel made by a surgical tool manufacturer for the shoe and leather industry. The business end of the blade is about the size of an x-acto, but thicker and about 6 inches long into the handle. You just advance the blade and sharpen when necessary until it's gone. It's really a cool knife. I use it to cut all my cardstock patterns, leather parts and heavy fabrics like cordura. This is the knife. https://shoetechnik.com/kobito-leather-knife.html
In the past, I never really sharpened this thing beyond 400 grit, because it dulled so quickly that I would have to sharpen it every day anyway. A refined edge was pretty much gone after 10 minutes of work, after which it needed honing every 10 minutes, which was no different than a less refined edge. So I settled for the toothy edge. But I just started hardening the blade with a quick torch and quench and edge retention is amazing now. Honing is down to about 10%-20% of what I needed before. I am able to see huge benefits from taking it up to 1000 or 6000 on my King KDS. Unfortunately it’s harder to sharpen now and the King cuts too slow. I need to start using diamond. I could get by with Edge Pro sized plates, but for about the same money, I can get full size Atoma plates on Amazon and use at least one of them to lap my King KDS 1000/6000 and they can also be used on my larger knives too. But I don’t know what grits to get. I tried sharpening this blade on paper to see how it worked. The only grits I had that were appropriate were 220 and 400. It put a great edge on. I would have finished it on the King 1000, but didn’t want to wait for it to soak this time around. I splashed my King 6000 and polished it a little and it turned out really nice. I think taking it to around 1000 is appropriate for regular use, but would settle for coarser if I could avoid a third stone.
Looking at the Atomas, the grit progression is not really set up well. Seems most people opt for using one or two Atomas and adding more grits of a different medium. I would like to have just two grits, or three if I could avoid soaking, and keep sharpening at work quick and tidy. I think the 400 would be good for lapping my King stones, but then 140 seems too coarse for starting on. I could go 400-600, but that isn’t enough progression to spend that much money on. So I am wondering if I should just try 140-400 and find something else in the 800-1000 range to finish on. Or, would the 400 cut fast enough that I could skip the coarser cutting I got from my 220 paper and just go straight to the 800-1000 and call it a day? But if I lap my King stones with it, will it remain coarse enough for long enough? And finally, any recommendations for the fine 800-1000?
I would like to stick with diamond because I hate having to wait for soaking at work, time is money. Splash and go stones sound good, but still are messy and everything I’ve looked at seems to cut slower that a water stone. Atoma 1200 is an option, but not sure if going from 400 to 1200 is going to satisfy me. I just wish Atoma would make an 800, my problems would be solved.
Thanks for taking time to help!
