You might think about putting a curve in the blade. Like a convex of the blade profile. Reason being is, if you want to chop something on a flat surface and it's below your waist/belly the tip of the blade will hit before the larger middle section of the blade. This could cause you to not even hit the target. I made one nearly identical to your first drawing, before I considered this possibility. Later, after consulting with some of the bladesport guys, I decided it'd be best to do a convex. If you look at a lot of the choppers in bladesports they have a convexed belley in the middle. They do a lot of cutting of dowels, golf balls, tennis balls, and whatnot on flat tables. They need to have as much of the edge hitting the target as possible.
Just a thought.
